Greetings,
This is my first post, I will do my best to not sound too noobish.
I have had my silvia for 6 months and I am in the process of dialing it in for more serious usage. Alot of reading has been done on my part, and I feel like I reached a point where I needed to ask a few questions.
In order to get the most of of this machine, I am trying to see where the settings are now for pressure and temperature.
So, I made a portafilter gauge, I got parts from McMaster Carr, and the 200 psi glycerin gauge from there as well. With teflon tape and the removal of the basket, I was able to make a good seal at all connections. I am using a needle valve to approximate espresso flow, and I made a small movie of my efforts this evening. I am recording 12 bar at the gauge, with the valve somewhat open, if my technique is correct. I tightened up a few leaks afterwards and retested several times, all with the rapid climb to the 12 bar level. In the movie, it can be seen that when I adjust the valve to open it slightly more, the gauge pressure dips momentarily, then raises again to 12 bar. Here is the movie...
http://gallery.me.com/portergieske#100521That's a little high, right? I was under the impression that the opv was set to open at 10.5-11 bar.
I am happy to report that I found and ordered the newer version OPV from a reputable shop online, this one is the more easily adjustable one from the V3. This should end my troubles in this area.
Now for temperature-
I bought a nice digital thermometer probe, one with +-.5 a degree in Fahrenheit. Its a food probe model, not too fancy or pricey, but it is exact, I calibrated it too.
Here's what I found out from testing it tonight:
I used a double walled stainless steel mug, one that doesn't quickly lose heat. I began the test after a moderate warm up time of about 30 minutes. I wanted to start low to see the temps rise. I put a portafilter in with no basket and no diverter below, it was after I removed the gauge piping. I flowed water through the grouphead and saw temps in the low 180's. I kept the water in the cup and the probe in the water and waited for the boiler to cycle until the light went off. My process from here on out was to dump the water, replace the probe and run water into the mug. Round 2 went into high 180's. Cycle 3 saw high temps of 195, at about 6-7 seconds into the pumping. Everything seemed to be getting hotter and holding it better. Dump and rerun cycle 4 and it went to 199, held there, then slowly dropped off to 197 as the pump light went on near the end. Now I can only run the pump for about 6-7 ounces, due to the size of the mug.
I let the boiler go a full round and when the light turned off, I dumped the hot water and ran the pump. This time, I definitely saw 202.5 for a few seconds, right at the start of the flow of water. It began at 199, shot up to 202.5, along with sputtered out steam as well, then dropped to 201, 200 and held for the filling of the cup. I consider this to be just a guesstimation of the real temps inside the portafilter, my test was just to reconfirm that the old lady was still able to kick out nice numbers. I had to quit at this point (kids), but it tells me that 1) I need to let it really warm up for the higher temps and 2) I can now look into figuring out how long to wait to surf for the right temperatures. My plan there is to count seconds away after the boiler light goes out, and not try to hit the temp with the boiler on the rise.
I have had fair to good results despite my high pressure and low temps. I use a naked portafilter to improve my tamping and dosing technique. I use a quality digital scale for dosage, and I in full understanding of grind optimization for flow volume at specified duration. That all makes sense to me. The designer in me is dying to make a 30 pound tamper from a precision spring and some tubing, all I have to do is attach the coffee tamper base and mark the calibrated level. Much like the spring loaded hole punches, without the click and kickback.
Comments are welcomed on where i stand with all of this, I have already swapped out the steam arm and valve for the new version, that helped the foaming some. I feel like I am making some good cappas, milk hides alot. I am very much enjoying the journey, and I feel that there is a nice long way to go before I make serious espresso.
thanks
