by Whiplash Willy on Fri Apr 15, 2011 11:29 am
So yesterday I tried brewing first, then steaming. I brewed the shot for my drink, then ran water through the brewhead for about 10 sec while brushing it to clean it. I then switched on the Steaming Switch.
I filled the 20oz milk pitcher about 1/3 of the way full and started frothing once the heating light went out, and I had bled the water out of the want. It frothed like usual, and didn't seem to start running out as I finish first pitcher (Sometimes it does, sometimes it doesn't).
I then starting preparing for my wife's hot chocolate. I turned off the steam switch and turned on the Hot Water switch, and waited for a stream of water to come out. I then turned off the water switch and turned back on the Steam switch and waited for it to heat up. I filled the 20oz pitcher again to 1/3 full, waited for the boiler light to go out, and purged the wand again. This time it steamed amazingly! It was quick and quiet, I was able to froth the milk in about half of the time it took for the first one! I finished cleaning up, and filled the boiler by running hot water through the wand again until it started coming out as a stream.
Thinking that filling the boiler with the steam wand before steaming would reproduce the same great results as yesterday, this morning, I tried it again. I brewed my shot first, and then ran water through the brewhead for about 10s to clean it. I then ran some water through the wand to fill the boiler, and it came out in a stream after a few sec. I then flipped the steaming switch and waited for the boiler light to go off, and purged the wand of water. This time when I steamed its performance was poor. It started out to froth like normal, but started running out of steam in about 30 sec, before I was finished frothing.
I don't know if I am doing something wrong, or if something is wrong with the Silvia. I will keep experimenting, but this is starting to get frustrating!
