A couple of comments:
1. Cracking the steam valve is also a very good idea from the temperature control aspect. A Silvia shot is characterized by an initial spike in temperature to around 208F - 210F (measured in the brew path using an Eric S adapter and thermocouple). This initial spike, IMO, serves no useful purpose. By cracking the steam valve for a few seconds before pulling the shot, the spike can be virtually eliminated, with an accompanying improvement in the intrashot temp profile. This is because the short bleed allows the superheated steam/water that congregates at the top of the boiler to leave the building with Elvis before the shot is started.
2. The second characteristic of a Silvia shot is a rising temperature profile after 15-20 seconds (measured at the puck using a Scace device). Like the initial spike, I don't believe this rising profile serves any useful purpose. I believe it is better to eliminate this late-shot rise to the maximum extent possible. So considering the natural tendency of a single boiler shot to have a rising shot profile anyway, adding more heat to the mix (by using the steam switch) does not sound like a step in the right direction to me.
From the temperature standpoint, with a Silvia you will get the most level profile by cracking the steam valve for a few seconds immediately before pulling a shot, and by keeping the heating element turned off until the shot is complete.
The idea that the quickly dropping temperature at the top of the boiler translates into a dropping temperature in the water hitting the coffee makes sense, but it is wrong. In fact, the temperature at the coffee will continue to rise slightly even after the temperature sensed at the top of the boiler has already dropped 10F to 20F during a shot.
I have observed and measured this literally hundreds of times in the course of designing, testing, and building PID systems. The graph below, chosen randomly from testing done this week, illustrates typical behavior of the temperatures at the top of the boiler, and in the brew channel (no steam wand bleeding was done).
Jim
