by JeffBlouin on Sun Feb 20, 2011 11:14 pm
Hi,
I just bought a Quick Mill Anita and a Vario grinder after doing alot of reading on this website. So first off all, I have to thank you all for your great advices! But now I have a lot of questions...maybe too much.
I have been playing with my new setup for the last week and my results are quite disappointing (I'm sure that the problem is on my side...). The Anita has a boiler pressure of 1,15-1.35 and the brew pressure goes to 10.5+ with the backflush .
1)Are the boiler pressure and the brew pressure a little on the high side?
2)After what I think is a good flush (as explain in the article ...love the HX), I grind a full basket (double basket), level it with my finger and tamp with 30 lbs of pressure measure on a scale. All this in about 30 seconds. When the shot starts, the pressure gauge doesn't move at first and the coffee starts to flow after about 5 seconds and it's very dark, after a couple more seconds the pressure gauge starts going up slowly but never fully reaches the 10,5 bar and even less than 9 bar (which I think should be the target pressure).When the pressure starts to go up, the coffee gets to the nice color I see in all the videos I have been watching...
I have tried with a lot of grind and even at the finest setting on the vario I get something along those lines. So my question is: is this normal for the pressure to build up slowly and never quite reach the target pressure and for the coffee to start dripping when the pressure is still at 4-5 bar?
3)When I grind for 10 seconds which is suppose to be 20 grams on the Vario, the double basket is not close to be full... I thought that a double could be pull with 14 or 15 grams... I have to grind for about 12 seconds or even more to fill the basket and be able to level it... To fill the basket in 7.5 to 10 seconds, I have to grind a lot coarser and the espresso just poor very quick...
On the bright side, I've made the best microfoam I have ever experienced this morning!
Edit #1: I forgot to mention that I wait about 45 minutes for the Anita to heat.
Sorry for the long post.
Thanks for your help.
Jeff
