malachi wrote:It's harder to pull a good tasting shot based upon time and volume than it is to pull a shot based upon extraction. This is why few if any experienced baristas use timers and measuring devices and instead simply watch flow / rate / color and terminate shot once it's done.
But "experienced baristas" in a work environment have a number of advantages, including the fact that they pull shots repeatedly and have the opportunity to adjust their grinders frequently to adjust for the various variables which change. Home baristas typically pull only a few shots each day and if they allow their equipment to "drift" too much from some idealized standard pour, they are going to end up pitching a very large percentage of the shots they pull and could even double their expense for coffee with the excess literally going down the drain.
malachi wrote:If you pull shots based upon a desired extraction for your specific coffee and your own personal taste (flow / rate / color) sometimes you'll end up with a 0.75oz double. Sometimes you'll end up with a 2oz double. Sometimes you'll have a 2.5oz double. It all depends on your coffee, your grinder, your machine, your technique and even the environmental variables at play -- coupled to your own personal taste.
Certainly, this is what I do and what most experienced home baristas do, and it definitely helps to have a "better grinder" such as a connical, a huge planar, or a hybrid Max, as the grinding system will be more tolerant of small differences in other factors and a much higher percentage of acceptable pours will occur in spite of these variables.
I use a timer 90% of the time, and recommend the use of one to most people. The way that I use a timer however differs from what some might think. The purpose of the timer is not to tell you when to cut your shot, rather, it is to tell you when to adjust your grinder. This is much more critical for your typical small planar grinder than it is for a big connical or hybrid Max.
If your machine has some sort of pre-infusion (I would argue that most or all vibe pump machines have this as an inherent "feature," with their slow pressure ramp up) that cuts out after around 6 or 7 seconds, then you have another easy guide to knowing when to adjust your grinder. If you start getting espresso coming out of your PF before the preinfusion has completed, you need to fine up the grind. If on the other hand you don't see any espresso coming out even several seconds after the end of the preinfusion period, your grind setting could use a bit of coarsening up.
ken
