Pulling Americano Water through HX
Postby Grant on Mon Jan 19, 2009 6:17 pm
Never really been happy with the Americano's I have made previous to this point. After playing around this weekend, I just confirmed the problem has been using HX boiler water...I suspect the problem is the temperature specifically (not "quality" of water) as I have refreshed the boiler water (it is a plumbed in machine) as a test a couple time by repeated flushing and it makes little difference - the only common puzzle piece is the high temp. My wife pulls a lot water from the boiler for tea as well, so the boiler water is completely exchanged often.
Am I missing something else? Is water temp THAT critical to a great Americano?
I have tried mixing the overly hot boiler water with some cooler water first and then pulling the shot into it which helps, but is hard to accurately get the temp close each time so it is a bit hit/miss, and I have never seem to get a great result.
Then this weekend, I thought I would just try using the group head water knowing I can hit targets temps pretty easily at set time intervals. So, I pulled my shot, and then added water from the HX/grouphead two ounces each time x 2 times at set time intervals.
Wow...great Americano, and I can repeat the result with my eyes closed. Anyone else using grouphead water for Americano's? If not, how are you doing it?
Grant Thompson
Grant
Postby RapidCoffee on Mon Jan 19, 2009 6:56 pm
This doesn't surprise me in the least. There's been a related (but badly off-track) discussion in this thread. The brew water on an HX machine is fresh, and heated to roughly the right temperature. The boiler water is stale and overheated for tea or coffee.
John
RapidCoffee
Postby Address7 on Mon Jan 19, 2009 7:19 pm
My wife often asks for Americano's, I also pull water from the grouphead. In fact, I use a room temp cup, run the cooling flush into the cup (result: 4-5 oz of water), then lock in the portafilter, pull a double or triple shot and throw it in the cup. Just guessing, but everything probably turns out about 195 - 200 F, about the same temp as brewed coffee, and it's very quick. She says they are great, and I can't be bothered to think about it any more than this - I have some cappas to make!
Given that I have a new toy (bottomless triple pf), lately I have been making her a caffe crema; it's a nice alternative to an Americano, with more flavor and body (but less than a double shot).
Enjoy your experience.
Address7
Postby JohnB. on Tue Jan 20, 2009 9:19 am
I use the hot water tap on my S1 Vivaldi for Americanos & they always come out quite nice. If I run 3oz of water into a warm 5oz cup the water temp in the cup will be between 195-198*F as its cooled in the tap pipeline for awhile. I can raise this up to 202-204*F by letting it run for a short period. The steam boiler gets completely refreshed several times a day so I'm not concerned about stale water in my boiler.
Grant - What is the temperature of the water in your cup immediately after you draw it from the HX boiler?
LMWDP 267
JohnB.
Postby Dogshot on Tue Jan 20, 2009 10:39 am
I really enjoy the occasional Americano, and I find that while it is almost never a problem if the water is a bit too cool, the taste really suffers if the water is too hot.
I have a DB machine, so I heat my 3-4oz of water in the microwave for 75 seconds while I am preparing my shot. I then then brew into that water and wahla!, a perfect Americano every time.
Mark
LMWDP #106
Dogshot
Postby woodchuck on Tue Jan 20, 2009 3:00 pm
I'm with John on this one. I pull 3 to 4 oz of water into a cup from my hot water tap then go about prepping and pulling a double into the cup. The water is sufficiently cooled by the time I get the shot into the cup. I especially like SOs as Americanos. I find the the extra water mellows the acidity but brings out the unique flavours from the of that origin.
Cheers
Ian
woodchuck
Postby MrMonkey on Tue Jan 20, 2009 4:35 pm
I almost always use the thermometer I bought for milk to measure water temperature while making americanos. Milk temperature is now by touch, so the thermometer rarely gets used for anything else. I just fill a warm (from the top of machine) cup with water directly from the steam boiler on my S1. Then, I go about preparing the shot. But, I don't start pulling the shot until the water in the cup has cooled to my desired temperature. That is 180F for me, but your tastes/preferences/thermometer may vary.
MrMonkey
Postby cannonfodder on Tue Jan 20, 2009 10:07 pm
I find the boiler water to be stale and only use it for heating cups or filling a pan to make macaroni. If I need hot water for something I draw fresh cold water from the sink and will flash heat it with the steam wand.
cannonfodder
Postby another_jim on Tue Jan 20, 2009 11:07 pm
Boiler water isn't "stale;" but if you check it with a TDS meter it reads very high due to leached copper (the readings exaggerate the amount, since the calibration is for calcium, but it's there and tasteable if you let the water cool). It is also overheated. The best technique if you need to use it is to draw it first into the cup, then grind, dose, and pull the shot. Consider a machine with a stainless boiler or a hot water HX if you really want to use a lot of water from the boiler.
another_jim
Postby JohnB. on Wed Jan 21, 2009 10:58 am
another_jim wrote:Boiler water isn't "stale;" but if you check it with a TDS meter it reads very high due to leached copper (the readings exaggerate the amount, since the calibration is for calcium, but it's there and tasteable if you let the water cool). It is also overheated. The best technique if you need to use it is to draw it first into the cup, then grind, dose, and pull the shot. Consider a machine with a stainless boiler or a hot water HX if you really want to use a lot of water from the boiler.
The Vivaldi uses a brass steam boiler so no copper.
LMWDP 267
JohnB.
Next
Return to Tips and Techniques
