JohnB. wrote:If that is truly the case then you will be tasting it in your macaroni & that "fresh cold water" you are injecting with the steam derived from your "stale" copper flavored boiler water. Meanwhile I'm going to draw some more water from the hot water tap of my S1 & make another Americano.
John raises an interesting point: I think he's suggesting that if excessive minerals/metals are dissolved in the boiler water then you'd taste them in a cup of cold water that was heated using the steam.
I don't agree. I say that the steam coming from any boiler will be relatively pure H2O, and will not carry the dissolved metals or minerals. It is essentially going to be distilled water coming from the wand.
If this is the case, then you'd expect that boiler water to contain higher and higher concentrations of minerals/metals. Not being an owner of an HX machine, I'm not familiar with recommendations for flushing and refilling the steam boiler. But it seems like it'd be a great idea to completely replace the liquid frequently instead of continuing to just add make up water.
Jim
