www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Proper distribution technique when "down dosing" using WDT
Postby beans on Mon Jan 28, 2008 6:43 pm
I have an La Spaz S1 mini (53mm portafilter) and I dose it with between 16.5 and 17.5 G of espresso from the Mazzer E doserless. I use a chopstick and stir the grinds WDT. Then I tap the portafilter on the counter to settle the grinds. The problem is that when I use this amount of coffee the grinds do not mound over the rim of the portafilter. This makes a level distribution almost impossible. However, when I tamp, the tamp is just at or slightly below the retainer ring, so the amount of coffee seems correct. There is an imprint from the nut but not the screen after the shot. Shots are between1.75 and 2 oz, between 25 and 30 seconds long. Lots of crema (90% ish), tiger striping, good taste, ie pretty good. The problem is that there is usually (50% of the time) some channeling which I can clearly see using the bottomless portafilter. I am betting this is because of the distribution. Either that or I am tamping too hard....Anyone else have this problem? Any suggestions?
Much appreciated!
beans
Postby ChrisC on Mon Jan 28, 2008 6:53 pm
Here's what I do:
http://www.home-barista.com/forum...w-t5817.html#70268
Also, try a paperclip unbent so the end is straight, or a large sewing needle, instead of a chopstick -- you'll end up with a flatter surface that you can just gently shake back and forth to even out completely.
ChrisC
Postby woodchuck on Mon Jan 28, 2008 7:38 pm
Beans, 16.5 to 17 grams is still a fair amount of coffee for the S1. You might try dosing down to betwen 14 and 15 grams depending on the coffee. Also try your WDT without tapping the pf to settle the grounds. Usually WDT fluffs the coffee up enough or me to get a nice levelling wipe.
Cheers
Ian
woodchuck
Postby HB on Mon Jan 28, 2008 8:03 pm
beans wrote:The problem is that there is usually (50% of the time) some channeling which I can clearly see using the bottomless portafilter. I am betting this is because of the distribution. Either that or I am tamping too hard...
A canted tamp can cause channeling, but tamping too hard? That's a new one. As for distributing below the rim, I've excerpted my reply from the thread cited above:
HB wrote:
Dieter01 wrote:So the question... If you only fill a double basket with 14g, which is less than flush with the rim, how do you level?
I use the Stockfleths Move for Dummies:
Instead of resting your finger lightly on the rim of the basket, press down firmly so the bottom flat of your finger rides below the basket's edge. The curve of your finger will scrape off grounds as you rotate the basket. It's fairly easy to dose to 16 grams with a standard Faema-style basket using this technique; with practice, you can dose to 15 grams or less (the dose in the video was 15.5 grams). For extreme downdosing of less than 14 grams, place your finger across the basket with the tip of your finger riding below the inner rim while rotating the basket, scraping off grounds to the desired level.
It's a lazy man's version of what David suggested above with his curved plastic scrapers. For more ideas, see Dosing less than level with the rim of the basket.
That said, I'm a bit puzzled by your earlier comment:
beans wrote:I use a chopstick and stir the grinds WDT. Then I tap the portafilter on the counter to settle the grinds. The problem is that when I use this amount of coffee the grinds do not mound over the rim of the portafilter.
Why settle the grounds unless you want to updose? I don't tap, jiggle, or otherwise attempt to settle the grounds when dosing below 16 grams.
Postby Marshall on Mon Jan 28, 2008 8:06 pm
beans wrote:I have an La Spaz S1 mini (53mm portafilter) and I dose it with between 16.5 and 17.5 G of espresso from the Mazzer E doserless. I use a chopstick and stir the grinds WDT. Then I tap the portafilter on the counter to settle the grinds. The problem is that when I use this amount of coffee the grinds do not mound over the rim of the portafilter. This makes a level distribution almost impossible. However, when I tamp, the tamp is just at or slightly below the retainer ring, so the amount of coffee seems correct. There is an imprint from the nut but not the screen after the shot. Shots are between1.75 and 2 oz, between 25 and 30 seconds long. Lots of crema (90% ish), tiger striping, good taste, ie pretty good. The problem is that there is usually (50% of the time) some channeling which I can clearly see using the bottomless portafilter. I am betting this is because of the distribution. Either that or I am tamping too hard....Anyone else have this problem? Any suggestions?
Much appreciated!
How about this. You live in San Francisco, which has no shortage of great baristas. Go down to Ritual or Blue Bottle or any other great shop during their slow times and watch what the baristas are doing. Really watch them. If it's very slow, talk to them about what they are doing.
You will see it takes them about five seconds to prepare the grounds after they are done with the grinder. Then do what they do and forget all the other stuff you have read here about yogurt cups, gram scales, needles, haystacks and other rituals and talismen. :D
Marshall
Los Angeles
Marshall
Postby HB on Mon Jan 28, 2008 8:10 pm
Marshall wrote:You will see it takes them about five seconds to prepare the grounds after they are done with the grinder. Then do what they do and forget all the other stuff you have read here about yogurt cups, gram scales, needles, haystacks and other rituals and talismen. :D
You forget that they'll be using Roburs or similar grinders, which don't suffer from distribution and clumping issues like most grinders discussed on this forum. Every Friday I'm at Counter Culture's espresso lab and every Friday I don't think for a moment of employing the WDT. In the Robur's case, the WDT would only degrade an already perfect distribution.
Postby Marshall on Mon Jan 28, 2008 8:18 pm
HB wrote:You forget that they'll be using Roburs or similar grinders, which don't suffer from distribution and clumping issues like most grinders discussed on this forum. Every Friday I'm at Counter Culture's espresso lab and every Friday I don't think for a moment of employing the WDT. In the Robur's case, the WDT would only degrade an already perfect distribution.
Are you saying any barista without a Robur needs a yogurt cup?
Any barista worthy of the name can pull great shots on the average home equipment owned by H-B posters. It's just not that hard, and I think it's better to learn real barista skills than to develop a dependence on unnecessary crutches. San Francisco isn't Iowa. Any espresso enthusiast living in a barista-rich town like San Francsico should take advantage of the opportunity to learn from the pros.
Marshall
Los Angeles
Marshall
Postby HB on Mon Jan 28, 2008 8:28 pm
Marshall wrote:Are you saying any barista without a Robur needs a yogurt cup?
No, I'm saying pro equipment is a lot easier to use than home equipment. For the longer answer, see Why don't pros use the WDT? and The Weiss Distribution Technique is NOT a 'cheat'!
By the same logic, temperature surfing a Rancilio Silvia is a crutch, and I agree it is one... for overcoming poorly designed espresso equipment.
Postby ChrisC on Mon Jan 28, 2008 9:38 pm
HB wrote:Why settle the grounds unless you want to updose? I don't tap, jiggle, or otherwise attempt to settle the grounds when dosing below 16 grams.
Hi Dan,
*After dosing a weighed amount of beans only,* I jiggle the PF back and forth, just to get the grinds all nice and flat, and I tap the PF down on the counter to knock the fines a little deeper into the basket, thereby hopefully creating a little more resistance for a longer, more even extraction (especially with my Silvia, which I hear 'attacks the puck' pretty hard, or some such thing). But again, that's only AFTER dosing the amount I know I need -- it's not to try to cram a few more grams in.
Just to clarify that there are two different kinds of tapping. :-)
Thanks,
Chris
ChrisC
Postby HB on Mon Jan 28, 2008 9:48 pm
ChrisC wrote:I tap the PF down on the counter to knock the fines a little deeper into the basket, thereby hopefully creating a little more resistance for a longer, more even extraction... Just to clarify that there are two different kinds of tapping.
Thanks for the clarification, but I understood you correctly the first time. If you're using the WDT, there's already plenty of fines resettlement. Perhaps too much; look for very dark extractions that blond out early as evidence of this. I don't see a need for settling the grounds in this case, especially if the goal was to dose below the rim.
Next
Return to Tips and Techniques
