by lblampman on Thu May 10, 2007 9:56 am
Hi,
Sorry to jump in here so late (really busy and having trouble getting to the forums as often as I would wish).
I have the same setup you do; an AP with the Rocky grinder. I'll relate what I do since it's really simple. I did remove the portafilter rest on the Rocky doserless (it just pulls straight out if you haven't tried it).
I hold the portafilter under the Rocky chute and crank her up. As the grounds drop from the chute (they're pretty fluffy) I move the portafilter around to get the grounds to distribute more evenly (these are small movements). I grind until there is a slight mound in the center just above the rim of the portafilter; the edges are a bit lower. I take my tamper and set it on the grounds and lightly press down and when I feel some resistance I finish the tamp (maybe in the 20 pound range). On my basket the final level after tamping is just a hair under the ridge. I clean the ears of the portafilter and lock it in. To the outside observer the whole process looks like 1) grind 2) tamp 3) lock in the portafilter 4) pull the shot. The only "things" I'm adding are the small movement of the portafilter under the doser to even out the dose a bit and starting light on the tamp to level the grounds.
I'm a minimalist; I figure if I can't grind, tamp, and pull a shot without a bunch of other procedures in the way the dude on the end of the portafilter handle needs to get better. I also don't care much what the puck looks like when I'm done (unless it really went to soup or cratered), if the shot pulled well and it tastes good in the cup I'm good. I also don't worry about the dispersion screen impression; I always got one on my Silvia and it doesn't seem to bother my AP now. I still think consistency is the key; if you can pull bad shot after bad shot but they're all bad in exactly the same way you're doing better than someone getting superb shots mixed with horrible shots (unless they're testing). Do the same thing time after time and change one thing to see what the result is. [For instance, I think the dispersion screen thing isn't an issue for me because I consistently dose and tamp the same way and I suspect in the beginning I made adjustments for whatever affect dosing as I do had on the situation. If I try to dose down now I have to change the amount of grounds in the basket, likely the grind, and maybe even my tamping. That's too many changes in my opinion (at least for me), especially when I get shots I like with no fuss.]
I'll add one more thing that I've not seen mentioned...time. It just takes time to acclimate to a new setup. I don't care how long you've been driving, when you jump in a car you've never been in before there's a sense of disorientation. That goes away with time and the more you drive that car the happier your subconscience is and the more intuitive things become. Try as you might with your new machine, no matter how analytically you approach the thing, you'll do better and better as the "sense" of the machine embeds itself into your brain and you start making unconscience adjustments to tweak things; or you instantly recognize, even before it happens, that things just aren't "right" on a particular shot. I can tell the moment the tamper hits the grounds and I start to lightly press down whether or not my dose was correct; it's not because I'm focusing on (or obsessing on) the dose, its just a motor skill that's become so ingrained that if even the slightest thing is wrong I get a little warning sense.
Best wishes and enjoy that new machine!
Les
