by boar_d_laze on Fri Aug 12, 2011 6:15 pm
If small changes don't work, make big changes. What's the worst that can happen? You sink two shots in a row? Hey, it's only coffee.
The easiest variables to control are grind, temp, and dose. Coarser/finer; cooler/hotter; underdose/overdose all change the balance between bitter and sour. There is no one "setting" for any of these, let alone all of them in combination. There's no guarantee that any of them will be right from day to day with a given coffee.
You taste, you adjust.
What's going on with your espresso machine temperatures? You'll have to tell me. You haven't said what they were like before, what's changed other than possibly the temps themselves, or anything else which might inform. So let's go with, "?"
In the meantime, lower your brew temperatures by improving your "water dance" technique, taking longer cooling flushes and/or timing them so they're closer to the actual pull. That should push the needle away from bitter somewhat.
If your temps and steam pressure run consistently high, we'll think about other things. Otherwise, manage temps with cooling flushes.
The Gaggia Dose has serious limitations in terms of what it can do, and how consistently it can do it. It never makes it easy to make consistently good coffee even with good beans and a good grind. You may want to think about stepping up to a decent HX.
BDL
