Merle,
I am quite sure they're clean. The 2011 steamwand is a new one. For the old wand, I did use water from the tap to 'blow' into the steamwand's top, the water flow out of the 4 holes no problem. I do clean the steamwand immediately by wiping with a wet rag and then blast the steam for a few seconds. Unless there's something else that I miss?
I think..all these could be because of my technique that was learnt and adapted for 1 hole. But I couldn't figure out what was I doing wrong. Let's think out of the box like what you suggest: does the power that supplied to Cremina will make a difference? I suppose 1000 watts should be easily available from any outlet. I am just using it off a normal outlet that I wasn't sure how much waltage/power it supplies. Maybe I could try using a different outlet in another location tomorrow.The outlet was something like below. And I use the top alone for Cremina. The bottom one for modem, wireless router, Mazzer, and 2 fluorescence light bulbs.
Edit:After doing a little research on the net, it seems this *could* be my problem.
The total wattage capacity seems to be grouped under one circuit and I might have other outlets and lights connected to the same circuit. Will verify it when I have a chance. Can't let any possibility get away without testing.
