Pressurized portafilter and tamping?
Postby Pupa on Sun May 17, 2009 8:10 am
Hello all,
I'm attending a wedding in a week's time and the bride and groom have a La Pavoni Eurobar (the "normal" or the de Luxe model, I never got an answer when I asked which one they have). If I've understood correctly, both models have pressurized PFs.
The thing is, they have a tamper on their wedding list and I'm thinking of getting them one (58 mm). But I'm not sure of how it works with a pressurized PF - somewhere I read that you shouldn't tamp at all and somewhere else I read that a light tamp will suffice.
Do people level the coffee by hand and then go about making their shots?
I'd be very happy to receive some tips on this. I obviously think it's nice to be able to get the couple something coffee related but if a tamper doesn't work with their PF, it also feels a bit unnecessary. :|
Pupa
Postby another_jim on Sun May 17, 2009 10:08 am
A 58mm tamper won't fit.
Even a regular PF doesn't absolutely require tamping.
Leveling is a good idea on any sort of PF.
Unless you give them a Robur, they won't get proper espresso out of this machine; so don't sweat it.
another_jim
www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Postby HB on Sun May 17, 2009 10:25 am
A pressurized portafilter has a tiny exit that provides backpressure to slow the flow enough for brewing at high pressure and aerates the coffee to produce foam reminiscent of real crema. Tamping helps assure a uniform bed of coffee, but given the pressurized portafilter's design, a tamper would not serve much purpose. The inexpensive plastic tamper that comes with the espresso machine suffices.
From Is this filter design "normal"?
Postby erics on Sun May 17, 2009 11:35 am
Using the search function on this site with the key word "tamping" would deliver enough reading material to cause you to miss this wedding AND the reception. But one thing I do know is that after placing a reasonable amount of coffee in the portafilter basket, either the user does the leveling and tamping or the dispersion screen will sorta do it for you. With these choices, it is far better for the user to have control.
As Jim S. said, a 58 mm tamper will not fit and the best way to pick out a tamper for them is to visit some stores that carry this machine(s) AND various tampers.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby Pupa on Sun May 17, 2009 2:47 pm
Thanks for all the replies.
I do know that pressurized portafilters aren't any good really and I also used the search function on the forum but I didn't find anything directly related to my "problem". It's not my thing to criticize the couple's choice of espresso machine (even though I wouldn't get one of those), I'm just trying to find out whether it's a good or bad idea to get them the tamper they have on their list.
Even though the plastic fantastic thing provided with the machine suffices, I guess it still is more fun to use a tamper and do a light tamp with it.
Tomorrow I'll call a shop that sells espresso gear and ask them what they think. I think I'll also force them to try out which size fits the Eurobar PF :P
Pupa
Postby triptogenetica on Sun May 17, 2009 3:21 pm
Pupa wrote:I do know that pressurized portafilters aren't any good really
So, do you know if the pinhole is in the PF? If it's in the basket instead, you could get the couple a replacement?
triptogenetica
Postby Pupa on Sun May 17, 2009 3:39 pm
triptogenetica wrote:So, do you know if the pinhole is in the PF? If it's in the basket instead, you could get the couple a replacement?
Hmm, no, I'm afraid I don't. Will have to find out that tomorrow, too!
Pupa
Postby another_jim on Sun May 17, 2009 4:48 pm
We get these discussions a couple of times a year. IMO, it's fine being into coffee; but it's just plain boorish to go around preaching coffee, and you don't even have world or soul saving as an excuse, as you would for political or religious preaching. So my advice is to skip coffee gifts unless you know at least one of the two really would appreciate it.
another_jim
Postby samgiles on Sun May 17, 2009 8:42 pm
It would pay to check but I think it'll be 53mm. My first machine was a Pavoni "Espresso Plus" which I believe is the same machine but with an all stainless steel box. It had a 53mm basket and pressurized PF. I actually bought a Reg Barber tamper for it and always used it but now I know I probably needn't have bothered :roll:
LMWDP #169
samgiles
Postby espressoed on Mon May 18, 2009 2:42 am
There's a difference between a pressurized portafilter and pressurized portafilter baskets that I don't believe to be semantic. Dan's response post shows a pressurized basket, not a pressurized portafilter. I've read commentary from many users of machines with pressurized portafilters (Saeco/Starbucks and the like with a spring system in the handle itself) that indicate that tamping has little or no effect, thus I've no reason to believe it isn't so. On the other hand, after first receiving my Krups as a gift I used it for the better part of a year with the pressurized baskets and in my experience tamping absolutely did have an effect on the shots I pulled. Since moving to a regular double basket I've occasionally used the pressurized single basket to finish off a few left over beans from a fresh bag and confirmed my initial experience with the positive effect of tamping in the use of these baskets.
As far as the original poster is concerned, if your friends listed a tamper go ahead and buy them one. It's a wedding gift that they asked for; at best a functional gift they'll use often and enjoy, at worst a really nice paperweight--also functional. Either way it matters not to anyone but them.
All the coffee in Ethiopia won't make me a morning person.
espressoed
Next
Return to Tips and Techniques
