JonF wrote:Greetings!
I recently installed a La Spaziale Vivaldi S1 V2 and am having fun dialing in the variables. (but burning through a lot of coffee!!)
I am coming from a Livia 90 (that I had running without fail for almost 15 years) and using a Baratza Vario grinder.
I will note that my water pressure is low--20 psi. This is from my RO unit, but have used it for years. However, the flow rate is more than enough for the pump, and I adjusted the output only slightly to be 9bar at brewing.
Anyway, I have been playing with preinfusion, and have been wondering if the objective it to wet the entire puck or to prewet the surface?? (or, for that matter, if it is even a good idea to use it.) For example, if I set at 4 seconds then quickly shut the brewing off before the pump kicks in, it looks like about 60% of the the puck (15gram) is wet.
Jim and Ken did some testing of preinfusion a few years ago and I think they found that the effect of preinfusion was largely through better extraction (less puck fracturing). This effect was only present for fully wetted pucks. I could be remembering some of that wrong. In any case, 20 psi is barely more than typical boiler pressure, so I'm not sure that it would be sufficient to fully wet the puck over any reasonable amount of time.
Another argument for moving from your RO source is that depending on your incoming water chemistry, your RO could be acidic, and leaching boiler metals (here is a link that decribes how RO filtration can lower ph
http://www.freedrinkingwater.com/water-education2/ro-ph.htm). Even if that is not important to you, RO is widely believed to be a poor choice for good espresso.
You could consider adding a mixing valve to connect the RO filter output and the cold water tap. Or, it would be fairly easy and inexpensive to switch the S1 to a cation softener and carbon filter off the cold water tap.
Mark
