ventura wrote:I just got a Bezzera a few weeks ago. Espresso is best ever, BUT - the portafilter almost seems to turn back from the pressure, and a few water drops coming from the side....I know it sounds too much coffee or too fine
Even if you can't make the cut PF fit like the OEM, you might benefit from a fresh group gasket. Yours may have been sitting in inventory for a year or two, even though the machine is new. I routinely (every 6 months or so) experienced these symptoms when my Silvia's gasket was getting old and hard: reduced friction holding the PF on, easier tendency to leak, and more torque needed to lock it securely. A new one usually feels more elastic, crushes more and seals better, even when it's just finger-tight. At the very least, you'll have a spare.
