HB wrote:cafeIKE wrote:I later measured the puck pressure at 8.22bar, very close to ideal.
I know David Schomer says 8.2 bar is ideal for his blend, but I don't adhere to such absolutes for all blends.
I plead ignorance on the Schomer coincidence. The "8.22bar, very close to ideal" reference is to the generally accepted 8-9bar range for brewing espresso. Apologies for for not adding
after the decimal places. I'll endeavor to be ever more pedantic.
HB wrote: For example, Counter Culture recommends 9.5 bar for their Toscano blend.
@ 180°
@ 210°
Single/Double
14/18/25 grams
5/10/20/50# tamp
Macap/Mazzer/Swift/Compak
Change one, change all.
IMO, the only consistent in espresso is there is none. It's patently ludicrous for anyone to recommend a single "best at" parameter.
HB wrote:You may find lower pressures provoke less troublesome extractions while you learn the machine, then later decide 1.0 to 1.5 bar more increases the body or alters the flavor profile in a pleasing way.
My recommendation for OPV adjustment,
with caveat, is for a fundamentally identical machine upon which, after close to a thousand shots, I've found the recommended value to provide a pleasing balance over a wide range of coffees, both home and professionally roasted.
MY blend, MY roaster, MY profile, on days 4-7, MY grinder, MY 14.2±0.3g ±0.1g ±1 digit error dose, MY basket, NO WDT, MY 10# tamp, MY Vibiemme, MY puck temperature of ~198°F, MY puck pressure ~8.5bar, MY altitude of ~1050ft produces consistent shots that start evenly across the basket, tiger stripe nicely and deliver ~60ml in ~25 seconds after the first drop. REPEATEDLY. By all accounts, favorably regarded. YMMV.
(Surely, this is understood and does not require adding as a disclaimer.)
As mentioned elsewhere, TASTE is the only arbiter. ALL measurements are made after an iterative process of honing the TASTE ALONE. Pull out the toys every so often as an insanity check to ensure no drift toward the center of the curve.
If I try a pound of a commercial roast, I'm thrilled if I'm pulling great shots before half is gone: 50g for the grinder, 50g for dose, 50g for temperature and maybe 50 to 100g for OPV, should I decide it needs adjustment. Once a chap who was having 'issues' with his machine dropped by with a quantity of well regarded coffee I'd never tried. I pulled a double into two cups. I sank mine and he exclaimed "What are you doing?!?!? This is great!" No, this sucks. Wait. 4 or 5 sinkos later, explaining what I was doing AND WHY, I gave him another. "Wow! NOW I get it!"
Rule 1 : If it tastes like sh!t, it is. Make ONE change to drive the taste in the opposite direction.
