Playing with dose and grind - Page 2
Postby RapidCoffee on Sun Mar 18, 2007 6:00 pm
another_jim wrote:I don't start timing until I see the first drop -- that takes care of all the ramp up stuff.
The reason I went to this is as I dropped the dose in my experiments, keeping the flow characteristics (after a drop appeared) about the same, the dwell time got longer longer and longer. At 19.5 in the triple, I averaged around 4 seconds, at 12 grams I averaged around 8 seconds.
Argh. I would have predicted just the opposite. Is this due to faster pressure ramp up with larger dose?
John
RapidCoffee
Postby jesawdy on Sun Mar 18, 2007 8:14 pm
RapidCoffee wrote:Argh. I would have predicted just the opposite. Is this due to faster pressure ramp up with larger dose?
Me too.... but you have to grind finer to keep a comparable time... I guess grind trumps dose in dwell time.
Jeff Sawdy
jesawdy
Postby another_jim on Sun Mar 18, 2007 9:19 pm
I haven't figured this out yet, and I haven't posted the data before. It is a solid fact; I've observed it countless times in regular shot making. None of the doses I charted touched the shower screen, so that's not part of the effect.
I also think it is simply finer grind. My hypothesis (until someone tells me something different) is that the flow is determined only by the amount of fines. A lower dose requires a disproportionally finer grind to produce the same number of fines, and that should mean the water gets through the puck more slowly.
The alternative is that it's simply a question of filling up more headspace over the puck. If someone will give me set of baskets, identical except for depth, I'll test which one it is.
another_jim
Postby RapidCoffee on Sun Mar 18, 2007 11:12 pm
another_jim wrote:I got roughly linear changes too when I systematically changed dose and adjusted the grinder for similar timed shots.
another_jim wrote:I also think it is simply finer grind.
Sorry, I missed that. Thought you were just changing dose. Duh.
John
RapidCoffee
Postby bigabeano on Sun Apr 15, 2007 5:27 pm
another_jim wrote:I haven't figured this out yet, and I haven't posted the data before. It is a solid fact; I've observed it countless times in regular shot making. None of the doses I charted touched the shower screen, so that's not part of the effect.
jim
i realize i'm a month late replying, but could you mimic "same basket/different depth" by either using a gasket of a different thickness OR using a smaller gasket along with something to wedge under the "ears" of the portafilter, thereby making the basket effectively shallower?
scott
bigabeano
Postby another_jim on Sun Apr 15, 2007 9:29 pm
bigabeano wrote:jim
scott
That could work; but I advise wearing a mask while you work out the bugs :wink:
another_jim
Previous
Return to Tips and Techniques
