mitch236 wrote:So I came up with a solution. I am going to find a flexible heat tolerant tubing and wrap my steam boiler and put it in line with my water feed so that the water entering my machine is preheated. I have no idea how much heat I can transfer but that steam boiler is mighty hot!!
I'm sure this has been thought of before so I'm curious about how it turned out for others who have tried.
That is also what the expobar Brewtus (aka expobar minore) uses circa 2004
http://www.home-barista.com/expobar-brewtus-review.html"The Expobar Brewtus takes the current prosumer dual boiler machine design one step further by introducing an important element: It pre-heats the water via the steam boiler's heat exchanger before it enters the brew boiler, as shown in the diagram to the right. This feature is essential to Brewtus' jump in temperature stability and control.
The pre-heated water has another side benefit: It is practically impossible to outrun the machine. A typical prosumer HX will give up the ghost after 8-9 shots in a row if done in rapid succession. Most machines need time to recover. Incoming cold water from the water tank reduces the water temperature in the boiler, which affects the boiler's ability to quickly recover. Pre-heating the water before it enters the brew boiler tackles that problem. The Brewtus is capable of delivering 30 shots in 30 minutes without blinking, thanks to the routing of the incoming water from the pump to a heat exchanger passing through the steam boiler. The near brew temperature water then continues to the brew boiler.
Brewtus' innovation isn't really new since a similar feature is available in top commercial dual boiler machines like the Synesso Cyncra and the La Marzocco GB5, and has been a common commercial modification for more than a decade. Expobar's innovation was the application of an existing proven technology and implementing it cleverly to fit a specific need."
Cheers
