ubitalia wrote:The obvious question: Can the Pavoni Lever machines produce Crema from a can of pre-ground Illy Fine Grind?
HB wrote:No. ...
peacecup wrote:... Haven't figured out the steamer yet though!
To answer the question, NO, or at least very probably not....
Easy guys!
I wonder how to NOT get any crema from the preground Illy, my bad i used it over the years before finally investing all i got (20 bucks) in buying a handgrinder
ubitalia, no drops for 10-15 sec seem a bit long, and you shouldnt wait that long with the preinfusion, 6 secs should do. if you get initial crema that quickly vanishes I'd suspect that the water is too hot (you either warm up the head too much initially, or the long preinfusion affects the puck)
how hard do you have to push or pull - I found the Illy grind just right, if i used too much or tamped too hard it would choke the machine.
I dont know about the distribution system of Illy in the US, maybe we are better off in Europe - I used to buy it from supermarkets which i expected would frequently have to restock. I read that test about how quickly preground coffee gets stale - and I agree that it cannot be compared to freshly ground - still I got crema from preground even if it was opened 3-4 weeks earlier.
So, although you should move on to buy a grinder asap my point is that this alone might not solve the problem.
sorry about these pics - I did them for my girlfriend after she bought me a pitcher, to document my inabilities for latte art and give her a good laugh...
which brings us to frothing... there are some threads about it, and it seems a lot easier if you block one hole of the steamtip....
