- 1.) It's been said here that Italians typically don't updose (i.e., a double is 14 g.)
2.) A properly tamped 14g dose will end up well below the ridge in an LM double basket
3.) A 58mm tamper is stopped by the ridge in an LM double basket, so it can't tamp a 14g dose
4.) LM supplies a double basket and a plastic 58mm tamper with the GS/3
I've read that many Italian baristas use the tamper mounted on the grinder. Do those tampers typically run smaller than 58mm? In other words, is the LM double basket intended for use with a smaller, grinder-mounted tamper? If so, is the GS/3 combination of the LM double basket and 58mm tamper intended for non-Italian updosing countries like the U.S.?
I was reminded of this paradox today when I tried to tamp a 14g dose in one of the two LM double baskets that came with my GS/3. Believe it or not, I've only used the stock double baskets a couple of times, and that was for updosed shots. My go-to basket has been the Synesso ridgeless double, which easily accommodates doses in the 12g-19g range, all of which can be tamped with a 58mm tamper. I just acquired a K10 and was curious about how the same grind/dose would fare in each of the baskets I have on hand. Out came an LM double -- and I couldn't tamp the 14g dose. I pulled it anyway and it produced a spectacular gusher.
The LM OEM double basket is referenced by Chris Tacy for all of his suggested extraction parameters in Favorite Espresso Blends 2010. It seems to be something of a standard. Is it considered primarily an updosing basket?
