Thanks for the help. The simple chart at Sweet Maria's was a big help. As was the article from several years ago, on HB "dialing in a new machine." They made me realize that I needed to address one thing at a time and that it was simpler than I thought.
This morning I made tiger flecked crema. It isn't perfect yet, but a huge leap forward. I tend toward over-extration still (also a problem before this machine). The grind and temperature may need fine tuning to really get the flavor/timing in the sweet spot. I know my grinder isn't ideal, but I haven't outpaced it in technique or knowledge. One of these days, I will outgrow it. In the meantime, I don't want to blame my equipment for my lack of skill or knowledge, invest thousands into equipment that doesn't fix my fundamentals. And as you will see below, I have a lot of room to learn
(very exciting to have new horizons).
Forensics of what I was doing wrong: 1) not letting the machine heat for 1 hour. I was too eager to use my new toy and only let it heat for 1/2 hour. (kept the silvia on a timer so it would be ready but haven't put this one on it yet). 2) didn't do a blank shot before beginning my routine, recommended in the manual and I forgot. 3) I thought it was a grind problem and started varying grind and tamping which just confused the issue. I put the grind back to what worked for the silvia as a starting point. It worked fine. 3) I was putting too much coffee in the basket. The silvia really seemed to do better with more and a very firm tamp - this machine likes less coffee and a lighter hand. 4) This one is important and I'll have to try to remember it: fundamentals before fancy adjustments especially on an espresso machine that can do so much.
Thanks!
