The best way to judge particle size is to watch the extraction and adjust grind accordingly. Particle distribution is a function of the grinder's design and manufacturing precision, quality and condition of the burrs, and age and roast of the coffee.
Your best tools if you are diagnosing problems or trying to improve:
- a gram scale for weighing dose
- a dissecting needle to assure proper distribution
- a bottomless portafilter for watching the extraction
- a clock with a second hand (or equivalent) to time the shot
- your palate
And as far as all that goes, since this is all new equipment to you, then the best tool for now would be about 250 grams of patience. It only comes in kilos, so you might as well use it all before going on.
