by Philg on Mon Dec 14, 2009 9:45 am
Without stirring anything up, I just wanted to say thanks.
[Nothing well documented or carefully tested below]
For quite a while I've been weighing, stirring and stockflething,
I've tried various other things, the pours never looked as consistently even.
I know, it's the taste, and I've had some good tasting ugly pours, but I figure a nice looking pour (coffee coming out evenly across the bottom of the basket) is more likely to reflect even distribution, and is my best chance at consistent good shots : nothing worked as well as all the fussing...
For about a week I've been nutating : dose straight into the basket in a heap, sit the tamper on top a bit, make a couple of circles with the handle, then tamp. I actually tamp, spin the tamper and tamp again - it cleans off the loose grounds and the tamper, and doesn't seem to hurt anything.
It worked the first time, has has worked pretty well every time.
I am using an 18 G ridgeless and pretty easy coffee (Klatch House and Joe from Ecco), 20 and one 21g weighing before I grind, cleaning the throat before dosing, so maybe not the toughest test.
I'll try some SO beans this week, and maybe a smaller basket.
So far I feel no need to return to the cut down pudding container and paper clips and I am glad.
[Alexia and SJ]
Thanks.
