I was thinking about getting the coffe into the basket as even as possible
and I usually twist the handle while dosing. But I use to hold it horisontal.
Today I have been holding the handle very much towards vertical and getting
the coffe first around the edges and then in the middle, doing this over and
over as I fill the basket. Then I level a little bit north and south because
I feel I can get gaps if I just level straight once.
I didnt weight any dose today just felt it while tamping and timing the shot.
I use to get the tamper in there and then look from 2 sides to be sure
its even before doing the tamp. I hope to learn so I dont have to do this
because it feels a little bit bad as it stops the motion and might create
other problems, but Im working on getting more and more sure about tamping.
I ran out of beans some days ago and used some old ones so the grinder was a little off.
I got new beans today and this is the first shot:
(When the cups are full they are holding 60ml wich is 2oz)
This took 58seconds, sprayed some and tasted bad.
The cup is less then half filled.
Second shot took 45s, also sprayed some but tasted nice.
The cup is between half and full.
Third shot was a little fast 33s filled almost to the max.
Less spray, but I thought it was gonna taste awful, to my surprise it was actually nice.
Fourth shot gave me about 1,5-1,7oz and took 38s. This shot felt good, no spraying.
To my surprise it didnt taste good.
The best tasting shots were 2 and 3, both had taste and sweeteness
and seemed to roll off in the aftertaste. First shot was too sweet
and last shot tasted a little scorched with a harder aftertaste.
I tried to incorporate my temperature controlling technique but it
suffered a bit today because I was more focused on the dosing.
I am lucky enough to have a skilled barista having a coffeshop just outside my
window. I get my beans from him and they are 3days old. I have started to
only use the same beans as he does and I regularly go there to talk and to
drink his doubble. Im thinking about asking him up to taste my shots, he
has been here before but we havent really made any coffe.
I try not to get on his nerves.
