I again want to say thanks so very much for taking the time to help me.
What you guys say is invaluable and every time I come back
I read something that gives me that warm cuddly feeling inside (hope)
Not just this thread but many places on the forum. Great place this is.
I only had one more shot with that blend so I wanted to try higher dose.
Same grind at 17g almost choked but it sprayed minimal and in 1 minute
I got a single that was very interesting taste
So I put in the ethiopian from cafe fresco and gave it a try at 17g
and it came out alright. Not too much spray but it ran too slow.
The shot was sweeter then Im used to, and very strong.
It is looking a little brighter. Looks definitely like higher dose is
the way to go. Looking back, I always used to level with the basket
and it didnt use to spray so much, but still some.
I was too coarse then and a full basket gave me about 16g.
I was trying to test different doses and this is what lead me in the wrong path
I believe. I was a little blind trusting the scale and golden rule.
Im hoping it wont spray as I shorten the timing with 17g (now its over a minute for 1.25oz)
but I will try with the ethiopian later on.
I have that gauge you see in the video, but thats not it, is it?
It says bar in white and psi in red.
Bar scale is from 0-2,5
Psi scale is from 0-36
Idle:
Bar: 0.7-1
Psi: 10-14
After flush:
Bar 0.7
Psi 10
Brewing:
Bar: 0.8-1
Psi: 12-14
Yes basket is dry.
I saw that nicely made video here about making a shot (dont remember what it was called)
where he said to dry the basket because otherwise the coffee starts something
before you pull the shot and it sounded smart so ever since then I have been
wiping it.
Sometimes I flush over the handle and basket and then pop the basket
(leave the handle in the group) dry it, and then dose in the basket.
This is so I can use the scale everytime until I know what the
fudge is going on here
Sometimes I dose into another basket and pour it over, but its always dry.
