No distribution? No problem. - Page 2
Postby JimG on Sat Jun 13, 2009 9:53 am
JohnB. wrote:Are you using stock burrs or the Duraniums? I found I got much better results with the stock burrs.
I am using the stock burrs as well.
Jim
JimG
Postby Marshall on Sat Jun 13, 2009 10:38 am
JimG wrote:Anyone else made this "discovery?"
Yes. Discussed here: http://www.home-barista.com/tips/is-lev ... t9639.html
As a follow-up I should add that I have also stopped leveling and distributing with my Cimbali grinder. Slowing down the thwack-thwack-thwack allows the coffee to drop down without throwing to the left. I usually rap the portafilter on the dosing fork about half way through the grind.
Marshall
Los Angeles
Marshall
Postby JimG on Sat Jun 13, 2009 11:43 am
Marshall wrote:Yes. Discussed here: http://www.home-barista.com/tips/is-lev ... t9639.html
Oh ...... :oops:
JimG
Postby zin1953 on Sat Jun 13, 2009 2:19 pm
I, too, mostly use this technique -- both with my Cimbali Max Hybrid (thwak-and-tamp) and with my Mahlkönig K30 Vario (grind into pf-and-tamp) . . .
zin1953
Postby JmanEspresso on Sat Jun 13, 2009 3:52 pm
Yep, count me in.. I do the same. I used to do the WDT and "make" a mound just by my stirring action, then left off the cup, and tamp.
Now I dont use the yogurt cup, just some slower thwackage, a straight down tap of the PF on my tamping mat, and a straight down tamp, no twist/rap/polish.
One Thing I have noticed, however, is for me anyway, this doesnt work with a flat tamper. I get sidewall channeling and donuts extractions unless I use a convex tamper.
Grinder is a Mazzer Major. Works on my stock ridged E-61 double basket, and my ridgeless Synesso 14gr.
Oh, and for the triple basket, this doesnt work.. at least for me. For the triple, I WDT, and then tamp the mound I have created.. No leveling after stirring. Triple basket I use is the La Marzocco triple from Chris'.
JmanEspresso
Postby JimG on Sat Jun 13, 2009 3:58 pm
JmanEspresso wrote:One Thing I have noticed, however, is for me anyway, this doesnt work with a flat tamper. I get sidewall channeling and donuts extractions unless I use a convex tamper.
My tamper is flat, made by Greg Pullman, fitted to the double basket.
Jim
JimG
Postby cannonfodder on Sun Jun 14, 2009 9:43 pm
TimEggers wrote:Dave which grinder are you using? I've not had much luck with this (in the past) on my Super Jolly.
Cimbali Max
cannonfodder
Postby aindfan on Sun Jun 14, 2009 11:50 pm
JimG wrote:I watched the baristas at Ninth Street and Gimme pull great shots after no leveling of the coffee. They simply tamped the mounded coffee just as it came from the doser. No tapping, no Stockfleth, no Chicago chop, no nuttin'. Just grind, thwack, and tamp the mounded pile of coffee.
Do you know if the Gimme and Ninth Street baristas happened to be using a dosered Anfim at the time? I've asked a Gimme (Mott St.) barista about this. He said that because the timer is used to set the shot flow (grind size is not adjusted, only dose), touching the pile of grounds once out of the doser will defeat the purpose of the precise grinder setting as some of the coffee may end up on the counter and not in the basket (and to add to that, the Anfim doser works perfectly enough to make a pile that needs no distribution).
Dan Fainstein
LMWDP #203
PSA: Have you descaled lately?
aindfan
Postby RapidCoffee on Mon Jun 15, 2009 12:08 am
aindfan wrote:Do you know if the Gimme and Ninth Street baristas happened to be using a dosered Anfim at the time?
Doserless Robur E and Super Jolly at Ninth Street in Chelsea Market.
Doserless Robur E and dosered Anfim at Gimme. Said they use the Anfim for milk drinks.
Two Roburs (one doserless) and a Super Jolly at Cafe Grumpy.
Gimme grinders
John
RapidCoffee
Previous
Return to Tips and Techniques
