Hello All:
This is my first post after many hours of reading the wonderful discussions on this site! I may now know enough to ask more than the basic information, so I look forward to learning from all of you! Some of the most useful information I've read to educate myself is the series of three articles on the 1st Line web site teaching the fundamentals. See
http://www.1st-line.com/education/fundamentals.html .
OK. I'll have to admit it. Blue Bottle Coffee Company in the San Francisco Ferry Building completely opened my eyes and tastebuds to the difference between really good espresso drinks and coffee flavored foam. So I bought their beans, ground them in my blade grinder and loaded that in my 25 year old Krups steam espresso maker. Believe it or not, my trusty Krups machine brewed a really tasty double shot. But the steam wand clogged up, I didn't know about descaling, so I threw it out instead of risking an explosion in my kitchen. I went onto eBay and bought a refurb Saeco Magic Cappuccino Plus machine for $129. Then one of the baristas at Blue Bottle, with a knowing look, told me the grinder is more important and that to learn more, I should start reading this site.
I wasn't getting anything like what I'd even gotten on my Krups with the new machine and my blade grinder. My old blade grinder cooperated by burning out as I experimented. So I researched and bought the Lelit PL53 display model for $199 and quickly improved the results. But I still don't get the intensity of flavor they do at Blue Bottle.
I've now read many posts about the pressurized 53mm portafilter in my Saeco, including some that say you can still experiment with dose, grind and tamp and that the portafilter instead of being actually pressurized is only a valve that opens with sufficient pressure. It artificially creates crema. But I've researched that too and found that some like crema, others don't, but all say that without artificially creating crema with a pressurized portafilter, crema can be a sign of freshly brewed beans releasing their CO2.
I use fresh beans, properly ground. So my shots already taste good, not bitter, but I still don't get the full intensity like they do at Blue Bottle. I haven't been able to get any results like their rich, creamy and almost chocolately double ristrettos. So here are my portafilter questions:
1. Is it worth taking the "pressure" components out of my pressurized portafilter? I've found instructions for doing that online.
2. Will it make much more difference to find a bottomless portafilter? They're hard to find and I've read about mixed results using power tools I don't have! There are no 53mm bottomless portafilters that fit my machine online. The one source I found is out of stock.
3. Can I even hope to get anything like professional results with a 53mm portafilter compared to a 58mm that may allow higher dosing?
(I know that there are other variables like being able to control the pressure and temperature and pre-infusion but am not yet willing to spend for a Rancilio Silvia, a machine that you folks regularly use as a starter and then plunk down sufficient change to upgrade.)
Then there's soy latte foaming ... hmmm. Here's what I know so far. The brand of soy you use makes a difference. I'm using the same brand they use at Blue Bottle, where they're able to create lovely microfoam and finish it off with latte art. I've even found online instructions for latte art but am way ahead of myself here! The baristas at Blue Bottle tell me to be gentle with the soy, not oversteaming it. I've found if I overheat it separates and tastes bitter. I get better results with non-fat regular milk drinks for my wife. But I must use soy due to dairy allergies. I have watched that lovely online video that teaches foaming and latte art starting with dish soap but can't start to do latte art if I'm not getting good foam.
The best I can do so far is a fair amount of foam that isn't very micro and some of the soy separates. I've tried a low setting on the steam wand and get worse results if I let the steamer fully heat. I'll try letting the steam start outside the pitcher to make sure I'm not injecting water into the soy at first. (A little self-reproach here that I need to be more careful to vary one element at a time.) I do start with cold soy and a cold pitcher. I have yet to plunge my meat thermometer into the soy but am told to keep its temperature no more than 140 degrees F. To be more consistent, I should probably start with the steam function fully heated and adjust the dial until I find the right setting. Can you offer any other suggestions?
In all, I'm having lots of fun with this!
