by drgary on Wed Feb 10, 2010 2:50 pm
A brief update: I wasn't sure whether I was overextracting because didn't know whether the bitterness I detected was to be expected, especially since what I produce on my home machine isn't nearly as condensed as what the professionals do when making a double ristretto at Blue Bottle.
So I pushed the grind FINER on purpose by another 10 turns. This stopped all flow completely, so I had my answer. It was too fine. I then went coarser by 20 turns on the Lelit PL53. Success! (This is ten turns coarser than the bitter results I got yesterday.)
I now got a shot with real crema, not the artificially induced foam of a pressurized portafilter. The liquid underneath had good intensity for home brew but has just a hint of bitterness, which may be a natural part of the taste of good coffee. The taste I achieved is more "rounded."
BTW I tested my tamp pressure yesterday by using the tamper on a digital bathroom scale on the countertop and found that my usual firm tamp is 35 lbs. I'm a big guy and find it hard to finesse that much because when I press down with what feels like slightly less force it's about 25 lbs. I read more about tamping on this site and see that it's not critical that tamps are an exact ideal 30 lbs. Instead, it's important to tamp consistently and to rely more on grind settings to find the balance between under- and overextraction.
To get a result that is richer, I will also experiment with pre-infusion by turning on my machine, turning it off when I see the flow start, waiting 20 seconds or so, then starting and timing my shot. The folks at Blue Bottle do pre-infuse their shots.
Soy remains a challenge. I went too far and separated the soy today by overheating it and then ran too low on soy to try again. So I stopped by Blue Bottle on my way to work and asked advice again of the baristas. Both said foaming soy is tricky. It can tend to make thick bubbles that aren't suitable for latte art and even when it works well it's harder to get the detailing. One of them showed me how he gets a whirlpool going in the frothing pitcher and said he needs to finesse things day to day depending on how the soy reacts that day. He said one of the difficulties with some home machines is they don't have a single hole at the end of the frother, which can make it more difficult to get the whirlpool going. He also advised that instead of trying to build more bubbles, try to fold the foam into itself to let it build. This has me thinking about the whirlpool, which would fold in on itself. I'm currently using the Pacific Select Vanilla low fat soy they use but may experiment with others for their foaming properties. I've heard the Costco brand is good and will also read more about what properties of a milk-like liquid form microbubbles. I noticed too that he didn't just foam once but in one instance very briefly foamed some liquid remaining in the pitcher. I didn't catch whether it was milk or soy. I've read elsewhere that's not recommended but the result was good, even though usually they start fresh.
LMWDP#308
