Newbie Question: Why Adjust Boiler and Brew Pressure?
Postby mateo on Wed Dec 27, 2006 11:24 am
OK All, Please forgive the newbie question but I hear people talking about adjusting their brew and/or boiler pressure settings.
Can someone please explain why and or when this should be done. Can someone explain the advantages/disadvantages to adjusting either of these settings higher or lower?
I'm a new Anita owner and I haven't messed with Chris' factory settings, but I'm wondering if I should. Is there something I'm missing out on? In other words, could I be pulling a better shot if I adjusted either one of these settings?
mateo
Postby HB on Wed Dec 27, 2006 11:40 am
mateo wrote:Is there something I'm missing out on?
No.
See the section entitled What is the "right" boiler pressure setting? in How I Stopped Worrying and Learned to Love HXs. Briefly, the boiler pressure setting is a tradeoff of the desired brew temperature, steam quality, recovery time between shots, flush amount, and flush frequency. I recommend a boiler pressure setting of 1.2 bar for your Anita, measured from the top of the heating cycle.
The brew pressure should have been regulated prior to shipment. You may wish to experiment with it, varying the pressure from 8 bar to 10 bar; I recommend starting with ~8.5 bar. See Andreja Premium & Anita: Adjust brew pressure in Chris' Coffee FAQs for instructions.
Postby CyclingCraig on Thu Dec 28, 2006 9:59 pm
Hey Mateo;
I just received my Anita from Chris' Coffee Yesterday!! My Thread here: http://www.home-barista.com/forum...ng-pics-t2739.html
What is happening when you brew your shot, what is your brew pressure, I think mine shoots up to high?
For me, I grind, tamp, lock and load.
Then when I lift the Lever to brew, Pressure starts around 4 bar then ramps up to 10.1 bar, but my shots are taking less than 25 seconds. I figured with that high a pressure I would be on the long side rather than the short side time wise??
What is your experience so far?
-Craig
CyclingCraig
Postby miKe mcKoffee on Thu Dec 28, 2006 11:45 pm
CyclingCraig wrote:Hey Mateo;
-Craig
10.1bar during shot a bit high but still can pull a shot in 25sec range no problem, even totally stall the shot. On my old Silvia was way up 16.5bar no flow (prior to OPV mod) and with grind, dose, distribution, tamp etc. just right could even pull no spray nekkid shots in proper timing. However the shots will be more harsh/metallic than with better shot pressure. That said PF build off the slightest and too high pressure more easily leads to channeling which also leads to faster shot for a given shot volume. Not to mention taste gone south...
Mike McGinness, Head Bean (Owner/Roast Master)
http://www.CompassCoffeeRoasting.com
miKe mcKoffee
Postby timo888 on Sat Dec 30, 2006 10:29 am
CyclingCraig wrote:I figured with that high a pressure I would be on the long side rather than the short side time wise??
Although excess pressure can reduce or even stall the flow, flow rate is not in a simple inversely proportional relationship to the pressure.
Apart from setting the brew pressure, you optimize flow by changing the things that determine cake porosity:
--dose and headroom
--coarseness|fineness of grind
--preinfusion, or the comparable effect of a flow-restrictor in brew water path, which permits puck to be gradually saturated under lower brew pressure
--weight of tamp
--selecting single or double basket: single basket's smaller effective egress results in a more restricted flow relative to the double basket, although at 58mm diameter you might get channeling which would seem to produce the opposite effect, so the usual advice is to avoid the single basket until you've nailed the double
Freshness and depth of roast are factors that should be considered when you decide on on dose, grind, and tamp.
Regards
Timo
timo888
Postby BradleyB on Thu Jan 04, 2007 7:28 pm
HB wrote:No.
I'm trying to sort out the wisdom gleaned here and recommendations from Jason, a tech at Chris's.
When asking him about adjusting brew pressure, Jason recommended leaving it at the shop setting of 10 bar measured with the blank portafilter, to account for the pressure inconsistencies inherent with a vibe pump. Inquiring further, Jason advised that standard behavior ( 2 oz shot) would be to grind fine enough to bring the brew pressure straight up to the max setting and for it to stay there for the duration of the shot.
Here, in a post from Dan regarding setting vibe pump brew pressure, he notes that the OPV setting only comes into play when pulling ristrettos. This caught my attention because following Jason's advice, I have essentially been pulling ristrettos.
So, my question as I pursue decent 2 oz shots on my new Anita, should I be working toward a grinding, dosing, and packing consistency such that the resistance of the puck itself determines the brew pressure more so than the OPV setting? (I've dropped the brew pressure setting to 9 bar, which has improved the depth and body of the ristrettos.)
Regarding boiler pressure, my Anita came set up to peak at 1.1 bar and bottom at .95 bar, which I haven't played with yet. One at a time.
Thanks,
Brad
BradleyB
Postby cannonfodder on Thu Jan 04, 2007 8:55 pm
Yes. If your shot is fast, grind a little finer, or dose a little more volume, or tamp a little harder. Keeping things consistent are one of the keys to good espresso, and the thing that takes the longest to learn.
I would concentrate on getting your dose and tamp consistent, then vary your grind to get the proper extraction time and taste. Once you have the consistency down, then you can play with things like brew pressure, and dose for different blends. Espresso takes time and patience to master so do not get frustrated. It normally takes a new user a month to get decent shots, six months to get consistently good shots and a year to get consistently excellent shots. Practice, practice, practice.
Leave the boiler setting where it is for now. Once you can produce consistent shots, then you can start to think about changing other variables. One thing at a time.
cannonfodder
Postby BradleyB on Thu Jan 04, 2007 9:20 pm
cannonfodder wrote:Yes. If your shot is fast, grind a little finer, or dose a little more volume, or tamp a little harder. Keeping things consistent are one of the keys to good espresso, and the thing that takes the longest to learn.
Hey, thanks for responding. Just to underline this in my head: Your "yes" is also to say "Yes, the puck resistance and not the OPV setting should be the determinant of peak brew pressure during the shot." Yes? So I should be working toward a grind, dose and tamp that gets me to that golden rule (without blonding) but without the brew pressure maxing out the OPV for the duration of the shot?
Thanks, Brad
BradleyB
Postby HB on Thu Jan 04, 2007 11:13 pm
BradleyB wrote:So I should be working toward a grind, dose and tamp that gets me to that golden rule (without blonding) but without the brew pressure maxing out the OPV for the duration of the shot?
Well, technically it doesn't matter what the OPV is doing for the duration of the shot since it can only determine the maximum pressure. If you want the long answer, see Recommendations for pressure setting on OPV requested.
Regulate the brew pressure against a blind basket to 9 bar. The actual pressure during a shot will be slightly less than the no flow reading, but 9 bar is a good starting point
Postby BradleyB on Fri Jan 05, 2007 12:29 am
HB wrote:Well, technically it doesn't matter what the OPV is doing for the duration of the shot since it can only determine the maximum pressure. If you want the long answer, see Recommendations for pressure setting on OPV requested.
That link has the detail I was looking for. Thank you, Dan.
BradleyB
Next
Return to Tips and Techniques
