joshem wrote:Thanks for your help. When you say replace the group gasket, do you mean the seal:
http://www.happydonkey.co.uk/hd6005.html?
All these bits and bobs are pretty cheap and so I'll probably replace them all (shower screen, seal, baskets etc.)
That looks like it.
Here's a decent guide, with photos, for replacing it.joshem wrote:At the moment I am loathed to buy freshly roasted beans for two reasons: 1. money, 2. as I don't yet have a decent grinder I would prefer not to waste good beans on my current grinder.
I understand this, but I'd argue for trying it at least once with your current grinder, though, just so you know how far off it is. You might be surprised. If it's no better, just use them in a press pot (cafetiere) or something.
joshem wrote:I'm going to save for a decent grinder, a Rocky or something.
Good idea. Shop around, though, before you settle on that one. I don't know what prices are in the UK, but the $400 a rocky sells for can buy you a better grinder here.
joshem wrote:I will look into buying some citric acid - probably be a hell of a lot cheaper too. How do you go about descaling with it? Method and amount used etc?
I generally add a liter of warm water to the reservoir and 30 mL of citric acid powder, then stir until it's dissolved. Turn the machine on, and immediately (before it's had a chance to warm up) run 250mL through the group. Turn it off and let it sit for 10-15 minutes. Then run 250mL through the steam wand and immediately turn it off and let it sit for another 10-15 minutes. Repeat, for group and steam wand. (Add a little water if necessary to keep the hose from sucking air at the bottom of the tank.)
Then fill the reservoir with fresh water and do it again, waiting a few minutes between 250mL runs, alternating between group and steam wand.
This lets the solution sit in the boiler and steam valve for a bit, and makes sure you don't overtax the pump. You may need to run one more tank of fresh water through afterwards, to make sure you've gotten all of the solution out.
If your machine is really nasty, you may want to do this more than once.
Powdered citric acid is much cheaper than the branded descalers. I got a very large supply for free just by asking around on a local discussion list as to where I could buy it. One of the list members had purchased so much of it so inexpensively that he wouldn't take any money for a pound of it.
Seriously, though, once the machine is cleaned up and the gaskets replaced, you should give fresh coffee at least one try. Your grinder isn't up to the task, but it might be much closer than you think if you start with good ingredients.
