by TrlstanC on Fri Mar 12, 2010 2:25 pm
Fat free milk is more difficult to froth than whole milk (or 1% or 2%), but it's definitely still possible to get good results. My advice for foaming milk is to try to make one pitcher of really thick foam (chill the pitcher of milk in the freezer for a few minutes before hand, don't use full steaming power, and froth the whole time, keeping the tip right at the top of the milk - all things to increase the amount of time you have to introduce air) and then make another pitcher just heating the milk up as quickly as possible (bury the nozzle all the way at the bottom, and crank the steam). This will give you an idea of the range of possibilities and what the extremes look and feel like, then you can figure out where in the middle gives you the best results.
I force myself to do the same thing whenever I'm trying to figure out something new with espresso, like dialing in the grind with a new bean. Instead of making lots of little adjustments trying to hit the perfect shot the next time, I pull two shots, one that I know is going to be too fast, and one that's going to be too slow to get an idea of the range, and where I am in the middle, and then work from there to find the sweet spot. I don't have enough experience to guess the right range for a new bean at the begining, so this helps me from making a dozen 1/2 turn adjustments finer when I should be making a 6 turn adjustment.
I had the same problem when I was learning to froth milk, I tried to get it right the first time, making little adjustments, without realizing that I needed to make a couple big adjustments to get in the right range.
My only other advice is to keep notes, I've made the most improvement by keeping a notebook near my machine, and only focusing on making one change at a time.
