by robbbby on Wed May 18, 2011 6:57 pm
I'm getting slightly frustrated, not at the testing and tuning i'm going through but at the fact i'm wasting so much coffee doing so!
Anyways i've been using the same coffee for quite some time, forget the name, just some prepackaged brand that came in a foil bag with a vent. At the recommendation at a few of the users here i decided to find a local roaster and buy some fresh beans to possibly help me with a few small issues I was having.
I am using a Lelit single boiler machine and baratza vario grinder. After some inital troubles I adjusted the grinder to grind finer using the allen key adjustment method. It worked out that I was grinding my original beans perfectly at the finest macro setting and mid point micro.
Today I came home filled with joy that I was going to get to try some fresh coffee. Emptied grinder, ran it to clean out the reminader of the beans and filled the hopper. I tried it at the very same setting I was previously using. First thing I noticed was that it wasn't filling the portafilter up nearly as much, probably because the grind was so much finer then before? Anyways i've adjusted and adjusted over and over playing with grind size and times and i've got to the point where I have adjusted the grind and entire macro setting and still cannot pull shots. The machine just runs and runs and very slowly drips out coffee.
Is it normal to have to make so much of an adjustment between beans? I've already tossed out 4 portafilters worth of good coffee and haven't even pulled anything that would resemble a decent shot.
Edit - Finally pulled a drinkable shot, 2 full macro adjustments down from my previous beans.
