by prof on Tue Apr 26, 2011 8:47 am
Hi everyone
After waiting patiently for several months, I now have a new Vibiemme double boiler (V3). The initial excitement has worn off, and now I'm at the stage where I'm beginning to miss my Silvia, which I had mastered after several years, to the point where I could easily produce superb espresso and reasonably good microfoam.
With the new machine, the espresso is still all over the map, perhaps because I have been alternating between doubles and singles (it's been about ten days now). I have occasionally pulled a shot as good as the better to best ones on the Silvia, but it's still very inconsistent. I should mention that the grinder (in both cases) is a Mazzer SJ. I wonder whether I should change the burrs on that, though it was working fine with the Silvia.
I've been using about 15 grams to 16 grams of Klatch Belle espresso (which produced great stuff on the Silvia), and trying a range of grind settings on the SJ. Even when it looks good, it can still end up tasting thin and unsatisfying compared to a shot from the Silvia. I'm wondering about the temperature setting; I've tried setting the PID (which they say is offset to read the temp at the grouphead) to 199, 200 and 201. Sometimes a ristretto will come out luke warm. I wonder whether the offset algorithm is off by several degrees in one direction or the other? Or whether it's just me and I should allow more time and bags of coffee to fine tune.
As for stretching milk, it's hopeless. I've tried different kinds of milk (albeit mostly whole, not 2 percent--but again the same milk that worked well with the Silvia), I've read every FAQ on here and seen every video that I could find, I've tried angling the tip and holding it straight, I've tried a quarter turn of the steam valve, a half turn, and a full turn, I've tried floating the tip just beneath the surface, a quarter inch in, and deeper, I've tried holding the tip in the middle of the pitcher and along the sides--and all I end up with (apart from one or two flashes in the proverbial pan) is hot milk (160 degrees) and subsequently a very depressing cafe au lait.
What am I doing wrong?
