The therm is a few inches above the puck, so, IIRC, the temp you're seeing is 3-4F higher, then what the puck sees.
Further more..
around to 25s mark, during the shot, the therm should be the approximate brew temp.
However... Running an E-61 as a flush and go, IMO, requires a bit of a higher P-stat setting. Member TimEggers is a flush-and-go advocate for his machine, and he runs pretty darn hot, up around 1.45BAR, IIRC. I used the flush-and-go for a bit when i had the Anita, and I cranked the P-stat up to 1.4B. But, them temps your seeing
sound about right.. but, dont hold me to it. Your tastebuds are your best guide.. Cliche', sure.. but cliche's are so for a reason... cuz' they're true!
