Illyfex wrote:I tried the Illy coffee when I got my machine about a month ago -- it wasn't expired then . . .
Coffee is not like prescription medicine with an expiration date. Coffee is more like fresh fruit -- or better yet, fresh bread: you need to use it before it goes stale.
Are you familiar with the "Rule of Fifteens"? (It doesn't sound as if you are.) Well, with the acknowledgement that there are no absolutes in life, the "Rule/Guideline of Fifteens" states:
- Green coffee beans should be roasted within 15 months of harvesting, or they goes stale;
- Roasted coffee beans should be ground within 15 days of roasting, or they goes stale;
- Ground coffee should be used within 15 minutes of grinding, or it goes stale.
Therefore, when you say
Illyfex wrote: . . . and (it) wasn't half bad.
The answer is yes, it was. Get some good quality, freshly roasted beans, and grind them right before you pull your shot. You will never go back to Illy or to pre-ground, stale coffee again!
Cheers,
Jason
P.S. For a list of roasters favored by many people here on HB, you may want to check out this link.
