My E61 thermocouple adaptor vs. EricS' - Page 2
Postby jasonmolinari on Sat Feb 21, 2009 2:09 pm
Here is a video of a shot. This machine had been turned on about 1.5 hours earlier. 1st shot of the day. A tasty one too:)
jasonmolinari
Postby Elbasso on Sat Feb 21, 2009 8:29 pm
In the graph, Eric's rebound time is about one minute. Your rebound time is just over 20 seconds. I am guessing that if you would try to duplicate Eric's routine, you'll see a similar pattern.
In your video I see that your flush gets the water in the HX path below 200F. After 20 seconds it'll probably be around 200F and at that time your group is about 205F. Once you start the pull, the temperature drops because the water passing the TC is around 200F. When the water in the group is "halted" by the coffee, the group starts to heat up the water to 201. After this the group will slowly start to cool because of the cooler water coming in through the HX.
Of course I have no proof whatsoever that the above theory is true but in my mind it makes sense at least :?
I also have Eric's gizmo on my Andreja so tomorrow I'll experiment with your routine to see if it produces similar results. I do hope so, cause that would save time and water while resulting in a super steady temp. Wicked!
Cheers,
Bas
Creativity is the sudden cessation of stupidity.
Elbasso
Postby erics on Sat Feb 21, 2009 11:07 pm
Jason -
Your temperature results are very similar to the graphs of the Vetrano shown a little over half-way down on page 1 here: http://www.home-barista.com/tips/...adapter-t5125.html
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby jasonmolinari on Mon Feb 23, 2009 2:06 pm
ah yes, thanks Eric. Guess my TC isn't as weird as i thought!
jasonmolinari
Previous
Return to Tips and Techniques
