by Psyd on Sat Sep 01, 2007 5:34 pm
On the giant boiler (14 litre, yes, fourteen, not one point four) two group I have two wands. One has the five hole tip for two lattes or caps that gets the eight to ten ounces for two cappas as a minimum, and the other wand has four of the five holes plugged for a two ounce to six ounce froth. Less than two is too difficult to get anything usable out of, but anything over end ounces is too slow.
OTOH, on the Silvia, I can get twelve ounces frothed on the one-hole tip, but not much more, efficiently or easily, and it will run a three-hole tip fairly easily as well. I don't like the lack of control with a three-hole, but it'll push enough steam through it.
I think that the advice that you adjust what you have with the variables that are easiest to adjust (obviously, boiler size and the amount of milk you want in your drink are going to be the hardest to adjust) and solve the problems that you are faced with as opposed to finding the perfect alignment of planets and only getting it right on that day, is invaluable.
Try what you have, and adjust as necessary. Technique is the easiest thing to change, start there.
Espresso Sniper
One Shot, One Kill
LMWDP #175
