another_jim wrote:I don't know how the GS3 steam boiler is set up stock; but if it is set to 1.8 to 2 bar like other LMs, then the tips may not work as designed if you reduce the pressure down to 1.4. In all likelihood, the tips will roil the milk and incorporate air when fully submerged at the factory set pressure..
Interesting.
The factory sets the GS/3 steam boiler pressure to 2.0 BAR. At that pressure, and with the stock tip, I guess it's possible just submerging the tip would work. I never tried that because, as a newbie, I had read countless instructions for proper steaming that said to stretch with the tip partly submerged and then sink the tip to incorporate the foam. I can honestly say that before Jim's post I have never heard of just sinking the tip.
Like many GS/3 owners, I wasn't able to steam well using the "standard" technique with the stock configuration, so I got the EPNW 4-hole tip (smaller holes than the stock tip) and lowered the pressure. That seems to work pretty well. Also, Nicholas recommended a somewhat longer steaming time to bring out more sweetness in the milk (15 seconds, as I recall.) I recently saw a post that said just the opposite (steam as quickly as possible).
Guess I have yet another espresso lab experiement to perform: go back to the stock tip and pressure and see if it works to sink the tip from the beginning, and see if the sweetness of the milk is affected. I'll also have to check whether using skim milk makes a difference to any of this.
BTW, the stock GS/3 comes with the no-burn wand, which may make it work somewhat differently than the LM commercial machines. I switched to the burn-me wand when I got the machine, so mine should behave more like its big brethren.
