After reading Scott Rao's book and the info about preinfusion, I started running a little bit of water from the brew head onto the tamped coffee before locking in the portafilter. I thought this would be similar to what a more expensive machine would do but without any pressure (I own a *$ Barista machine). It sure seemed to decrease the number of gushers I had when I was grinding with my Kitchenaide grinder. I've since upgraded to a Mazzer Major and most of my problems with inconsistency problems are gone. I still do the "manual" preinfusion out of habit. Maybe tomorrow I will try to compare with and without the technique and report back.
Any thoughts on whether this technique is accomplishing anything close to the preinfusion you get on higher end machines?
Michael
