Anvan wrote:Espresso machines provide a huge advantage that eliminates the need for bottled fake-food glop: the controllable and unfocused heat with built-in agitation available from a steam wand. This enables the use of real chocolate starting in solid form. You can melt solid chocolate in a warming liquid with a minimum of problems, but don't ever try the opposite - adding liquid to melted chocolate - unless you're in the mood for a a grainy glob of separated goo.
Chocolate conveniently melts at the same temperature where you stop stretching the milk in the pitcher, but just as important it doesn't burn until it reaches a higher temperature than the 150-155 degrees at which you're done. .
I tried doing this by breaking part of a bar of green & blacks 70% dark chocolate into chunks and adding them solid into my steaming pitcher with cold milk then attempted to steam normally with my pre-millienium europiccola. What I ended up with was lightly chocolate flavoured steamed milk and a big glob of melted chocolate on the bottom of my steam pitcher :s
Maybe I just need to break the chocolate into smaller pieces? By grating it maybe?
