by jmayberry on Wed May 09, 2007 8:10 pm
I am looking for a plan to draw down the temperature that heat exchangers store between brewings.
I am trying to nail down a routine with my Expobar Office Control, a heat exchanger. It's an automatic, but I always use the manual brew button so I can shut off the pour when the color starts to change. I've read a lot about temperature surfing with Silvia, but that is not a heat exchanger, and I don't have separate hot water-steamer switches that the online method says to use. My machine only has the hot water knob for drawing hot water, and the steam knob. No pressure or temperature indicators.
I am not sure if the right method is to run water through the grouphead, (then the red light goes on) and then wait 20 seconds or so (my red light goes off after only a second or two), and then put the loaded PF in. Results are not inconsistent! All my other variables are stable--grinding, packing, tamping, etc.
Any help appreciated!
