Lower doses and channeling
Postby jonny2 on Thu Dec 16, 2010 11:01 am
I'm having trouble with dosing and channeling.
If I dose around 18-19 grams, everything is Okay but when lower the dose to 16grams or lower, everything is falling apart. Lots of channeling, bigger and bigger channeling holes in the puck surface the less I dose, more soupy puck and uneven surface, looks like a little storm has hit the coffee.
When I dose 19grams, it looks good with no obvious channeling, and the surface is even and with a small imprint from the screen.
I thought it should be easier to dose low and get a nice extraction?
Im using a Isomac Tea with bottomless portafilter.
jonny2
Postby another_jim on Thu Dec 16, 2010 11:04 am
Grind finer; low dose shots start slower and end faster.
another_jim
Postby HB on Thu Dec 16, 2010 12:09 pm
jonny2 wrote:Lots of channeling, bigger and bigger channeling holes in the puck surface...
Puck analysis aside for a moment, how does the espresso's taste change with lower doses?
jonny2 wrote:I thought it should be easier to dose low and get a nice extraction?
I agree, neutral dose weights (14 to 16 grams) allow a greater margin of error for most espresso machines, assuming the dose is consistent and the distribution is even. If you find otherwise, I would double-check your technique by referring to the reliable 1, 2, 3 punch for "idiot proof" recommendations and the Home Barista's Guide to Espresso for everything else. It also would not hurt to double-check the brew pressure; if it's higher than 9.5 bar against a blind basket, the margin of error is noticeably reduced.
Postby cafeIKE on Thu Dec 16, 2010 12:28 pm
IMO, e61 machines have a no man's land of doses for various combinations of basket and screen.
My theory is that a large dose is held together by the screen and a low dose by water pressure. The no mans land occurs when the puck starts out against the screen and as the coffee is extracted, the pressure from the screen drops causing channeling.
IMO, it's also important to pull more that one shot after making grinder adjustments. The first shot seldom matches the second.
cafeIKE
Postby Mayhem on Thu Dec 16, 2010 12:54 pm
jonny2 wrote:bottomless portafilter.
If this also implies a gigantic triple basket, try a different/smaller basket when using a lower dose.
Too much is not enough
Mayhem
Postby jonny2 on Thu Dec 23, 2010 5:28 am
HB wrote:It also would not hurt to double-check the brew pressure; if it's higher than 9.5 bar against a blind basket, the margin of error is noticeably reduced.
The brew pressure gauge shows 11-10.5 when using a blind basket. Is this fine?
jonny2
Postby jonny2 on Thu Dec 23, 2010 7:36 am
It get more sweet and bright but still cant get rid of lots bitterness.
jonny2
Postby HB on Thu Dec 23, 2010 9:21 am
Try lowering the brew pressure, that will reduce bitterness. I would start at 9 bar against a blind basket (~8.5 bar actual brew pressure).
Postby jammin on Thu Dec 23, 2010 9:34 am
not insult your intelligence, but
1.) how fresh is the coffee?
2.) do you normally get sweet shots from this blend/SOE?
3.) have you tried other blends/SOE's with similar results?
i also agree with the comment about headspace. it might be time to try out the old "nickel trick" - place a coin on top of your coffee cake and lock in the PF. you can adjust your dose volume until the coin just slightly makes an impression in the cake. this should help get your headspace in the ballpark. you may need a smaller basket to get good results with the desired (lower) dose.
~j
jammin
Postby Phaelon56 on Thu Dec 23, 2010 11:08 am
If your tamper is fractionally smaller than 58mm and fits fairly snug against the side of basket then try using a tamper that is 1 mm smaller. I have "57 mm" and a "58 mm" tampers. I can't get a tight tamp with the 58 mm tamper when my dose is below 17 grams and have experienced problems similar to yours (using Isomac Tea and LM double basket) when trying lower doses. If I switch to 57 mm then I have no issues.
Phaelon56
Next
Return to Tips and Techniques
