by spiffdude on Tue Dec 28, 2010 11:25 am
Hi,
Well, i've finally bought a digital scale and discovered i was dosing around 18-19 grams of coffee by volume. This came as a bit of a surprise since i was filling the basket without any tapping or knocking and was using a knife to level out the coffee. I thought i was almost under dosing... silly me.
So i've pulled a couple of shot at 14 and 15 grams and my pulls are too fast and my crema is thin(ner) and disappears quickly. They don't taste completely awful (in milk!) but i was doing better before, although on an inconsistent basis. Here are some observations at these weights:
- I can no longer level the dose since the amount of coffee is below the rim. I find this quite annoying but i'll get over it. I wonder why this is never the case in cafés, they always seem to fill over the rim and cut off the excess...
- Once tamped, the level of coffee is way lower than the rim, i'd say about halfway. I don't know what kind of basket i have, i have a low cost machine called Angeli from Faema in Montreal... i suppose it is a double
- After extraction, the puck has a layer of water on it, i can see a slight imprint of the screen nut but not the screen itself. Before, the puck would expand enough to get an imprint from the screen... do we care?
- Obviously, shots are a lot quicker than my usual 18-19 gram shots.
I guess the next step would be to grind finer to get back to the 60ml/25 sec norm right? The whole point is to get more consistency and possibly improve my shots a notch. I can never seem to get syrupy espressos like i get at my café (Myriade, they are one of the best here in Montreal)
Damn this forum, I've had too m..muh...mah..mmmm..much caffeine!
