I (Les) have been working on a ultra-smooth method for tamping the last two weeks -- you can just think of as LUST
Anyway, it all started with trying to find a way around the messy needle-yogurt cup method of WDT. I started layering coffee in the basket and using the edge of a spoon to lightly pat across the grind to break up any clumps. I thought it worked pretty well, and wondered if sharpening the edge of a spoon would work better. It didn't because it created deeper grooves as I broke up the grind.
I had a tablespoon-sized wooden spoon with a relatively wide edge that is also perfectly round. I tried the edge of that and it worked great to break up clumps:
However, I noticed as well that the spoon tended to create a concave pattern, and it occurred to me that might help create a seal on the side (I'd been wondering about that since seeing the concave tamper). I left it concave when I used my tamper on it, applying 30 pounds of pressure as usual, but results were inconsistent, sometimes channeling still happened.
I remembered something Cannonfodder said to someone in another thread, "Try down dosing. When I was fighting this problem 90% of the time cutting down the dose by a gram or so, grinding a little finer and tamping a little lighter made the problem go away."
So my next attempt was to make the grind a few notches finer, use one of Rancilio's deeper baskets (a triple?), but weigh only 16 grams of coffee for it. I then used the wooden spoon to first break up clumps (tapping NS - EW), and finally applied the deep curve of the spoon to smooth the finish of, and give a concave curve to, the puck.
The finer grind was very responsive to both smoothing and allowing itself to be pressed tightly against the basket wall. Here's the puck before last touches:
I did discover later that the puck needs some firmness or it will collapse a bit in the center during brewing; I watched on digital scale as I pressed the coffee in place and never pressed harder than one pound of pressure with the spoon. I had difficulty photographing the concave part of the finished puck, but you can see I leave space at the top of the basket:
There is the typical learning curve of figuring out the right grind, pressure to apply with the spoon, being careful to create a smooth even surface, etc. If you've been using the 30 pounds of pressure tamp, you notice the LUST puck comes out more wet than before; this is one that took 24 seconds to produce a double shot:
I can say I've been consistently getting the best shots ever. I noticed right away that espresso started coming out of the two spouts (of my double portafilter) at the same time and flowed evenly without sputtering (which was very different than what was going on before). Taste is much better too, which is what it's all about.
Okay, I stand ready to be critiqued. I don't have a naked portafilter (yet), so I can't observe how the espresso is emerging from the basket. If anyone is interested in LUST enough
My last little thing seems hardly worth starting a thread over, but . . . for all you using a thermometer that didn't come with a clip:
