SimonSoCal wrote:Koffe Kosmo,
Thanks for the video. I too have La Spaz. but no luck in using the four holes.
Can you please tell me what kind of milk are you using? Brand?
Also what is the size of the holes of your tip?
Much appreciate, I will try your way tonight. [moving it to the side]---Btw, it is better to station it with a block like in the video or use the hands to hold the pitcher?
It works with full cream or low fat milk equally well (In Australia I use Pura or Pauls)
Use a loose hand Simon
Oton (the video maker & La Spaz owner) used the block because he was holding the camera with the other hand
Here is the method Stretching milk with a 4 hole steam tip
There is a technique to using a 4 hole steam tip
So please follow these easy steps
Purge water from steam wand for a few seconds
Use a loose hand not stiff
At first use 300 ml jug and fill with cold milk to just under the lower part of pour spout
Place wand just under milk in the middle of jug at 90 deg (no angle) and only give it air in the first second no more and then just keep wand under the surface
Important - turn on steam knob to
"full steam strength" Allow steam to do the work and when milk starts to foam keep wand at 90 deg but move jug to one side until the steam wand hits the side of jug
This all happens in about 10 seconds and before you know it you have micro-foam
When you get the hang of it you can progress to larger milk jugs
Koffee Kosmo
