AndyS wrote:Luca, you make a good point that the flow always starts fast if the grind is too coarse. I was assuming that with a 0.6mm gicleur the flow wouldn't start at 2.5 secs even if the grind was off. But I could be wrong, of course!
She said she was updosing, so the puck is presumably up against the shower screen. This is going to lead to low dwell times regardless, and may minimize the difference a gicleur makes (less space to fill up with water).
