by JmanEspresso on Sun Jun 28, 2009 2:45 am
Could just simply be the Crema, doing what it does.. Dissipating.
If you pull a shot, and let it sit, the crema goes away.. eventually completely.
It is an emulsion, and not EVERY emulsion is stable. A vinaigrette, properly made, is an emulsion. Let that sit and you have, Oil.. Vinegar.. Herbs/spices.. separated from one another. Mayo on the other hand is a bit more stable.
Something I noticed a while back.. If you pull a shot of pretty fresh coffee, say, about 3, maybe 4 days PR, and right after you pull it, hold it up to your ear.. Sometimes you can hear almost what sounds like the "head" of soda settling,, albeit much quieter.
So, its possible this is whats happening, but because of the milk, you end up with the larger bubbles, which eventually pop, but take longer then crema because of the fat in the milk.
Its also possible Im wrong.
