cexshun wrote:I know I'm never going to get something as good, or probably even close. ....
Begin by considering that, in just one day, the coffee shop probably pulls more espresso from just one group then you do in a month. Beyond the experience that such a volume affords the barista, it also allows them adjust the grind and dose with more precision to match the other parameters.
Their equipment is adjustable and controllable to an extent that yours is not. One click on a Rocky is worth about 6 seconds of extraction, so if you are lucky you have maybe two choices for an espresso grind. They are using stepless grinders that have better burrs, more precise alignment of the burrs, better burrs, and far more selection on grind.
Their espresso machines have adjustments for temperature control as well as superior design for superior temperature consistency from pull to pull. These machines also have superior water delivery rates and pressures as well as better dispersion.
Even if you use the same coffee beans they do, they have the option to get a blend and roast that meets their own requirements as well as the ability to match all the above-mentioned adjustments to that blend and roast, and/or to match the blend and roast to their equipment.
So, can you get close? Maybe, occasionally, if you get lucky. And there is the rub. Even if you get close for a shot, how did you do it? What was the water temperature on that extraction when you hit the target? Can you dose, distribute, and tamp exactly as you did the last time?
So excellent espresso is a synergistic experience where all the factors meet, and that meeting spot is very small. I say all this, speaking from home-barista experience. I went from a Rocky/Silvia (very comparable to your setup), and later added a PID to the Silvia. That rig served me for 6½ years. From there I went to a Vibiemme Domobar Super and Mazzer Kony. The difference was dramatic from the first day.
So why bother sharing all that? The setup you have now will give you valuable experience towards narrowing the parameters as close as you can. To gain more control, you need to get a gram scale capable of .1 gram (or even .01 grams). No sweetness and little mouthfeel could be a distribution problem. I recommend a bottomless portafilter so you can watch what is going on DURING the extraction. This will reveal proper distribution. Look up the "teflon tape mod" for Rocky as it will help stabilize the upper burr. It reportedly can even allow a "mid-click" setting. Rocky is also known for its clumping and dense grind, so look up WDT (Weiss Distribution Technique). Finally, the temperature control problems on the Gaggia will be the greatest barrier between you and better espresso. It's not just the Gaggia but all entry-level machines (even Silvia) the thermostats they use have a wide range so the addition of a PID somewhere down the line will help. If you are handy you can kludge one together or just buy an entire kit. The only thing left is the time to get the experience to really know that setup and learn how to best control it.
With the above tips, you may want to get an extra pound of coffee some day and sit for an hour or three and just keep pulling shots with the attitude of a scientist.
Espresso is a journey with an ever-changing destination. Enjoy the trip.
