another_jim wrote:In the single basket of any given manufacturer, the grind for a 7 gram single is about the same as the grind for a 14gram double in the same manufacturers' double basket. An Italian bar using one doser click for singles and two clicks for doubles would not be able to function if the baskets were set up otherwise.
There are many threads on HB that address the creation of single espresso (is there a thread on the correct plural of the word 'espresso'?) Some discuss the change in grind setting and how to arrange the grind into the basket. Here is a photo of my 58 mm basket with 7 grams finely ground, tamped with a 49mm tamper but less than 30 lb force.
The resulting shot is thin, extracts promptly with drops into the cup before the lever is raised, but tastes good. The same grind, 14 gram dose in the double basket with 30 lb tamp also produced a thin shot with richer flavor. Because I stopped the extraction after 20-25 seconds, neither were bitter.
I think Jim's observation suggests an elegance between dosing singles and doubles that does not seem to actually work. Maybe someone with a metal shop and home espresso lab could design a single and double basket that really does accept the same grind and the same tamp with one dose for the single and double the dose for the double that produces the same resultant espresso flavor.
