by Nick on Thu Jan 04, 2007 7:51 pm
If performed perfectly, the WDT can indeed lead to what you might call lower shot volumes. I'm assuming you mean lower shot volumes in the same shot time?
Think about it this way: the point of the WDT is to improve distribution, right?
What happens when distribution is poor? Well, the water will find a flaw in the puck density and exploit it, and run faster through that flaw.
So then what if the distribution is better? There will be no (or less of a) low-density flaw for the water to run through, restricting the flow through the entire puck in a more even way.
So in the same amount of time, poor distribution on a semi-automatic machine like the SL70 can and will lead to a higher volume of resulting extraction. The problem is, the extraction has a significant amount of over-extracted volume.
I'd guess that your WDT-shot is also thicker in viscocity, and perhaps darker in color (at least the crema).
Nick
wreckingballcoffee.com
nickcho.com
