Italian blends vs 3rd wave with 18g basket
Hi guys. Tried the 3rd wave type beans with 18g of coffee with matching basket and I get it to taste like it should with 32-36 g extraction. I really prefer the high end Italian blends . With 18g of Italian blend coffee it is way too thick or concentrated.
Is this normal?
Thanks
Is this normal?
Thanks
- canuckcoffeeguy
What kind of basket are you using? VST?
And for the Italian blends, what is your beverage weight for the 18g dose?
Might also be good to know which Italian blends...
LMWDP #483
Some of those blends are designed to grow hair on the bottom of your feet.
A 18gm dose of just about any Italian blend is about 4gm over a double. Which may be the problem.
Is that the reason for weird hairgrowth...OldNuc wrote:Some of those blends are designed to grow hair on the bottom of your feet.
LMWDP #483
Yes I have a vst 18g. Been using Lavazza top class
Total weight of coffee is around 36g
So ratio of 1for 2
So ratio of 1for 2
- canuckcoffeeguy
Ok so that blend wasn't designed with updosing in mind. Meaning doubles with that coffee are meant to have closer to 14g doses. Try that. If you have a traditional double basket that came with your machine. That should tame the intensity.
Also, that blend has robusta in it. That has higher caffeine content. Although, people on HB have reported good results with Top Class, I'd recommend also trying something from the recommended roasters which ship beans immediately after roasting. Good luck!
- canuckcoffeeguy
Also, since you're in Montreal, ceck out the Canadian roasters thread. Search HB for threads specific to Montreal. I've seen some before discussing local Montreal cafes and roasters.
Canadian Roasters: Canucks...What are you drinking?
